2014 1.2tsi toledo Door Seal
Oct 9, 2020
Hi
I have my Toledo around 1 year now. The previous owner seems to have rubbed off the door seal, and its worn away and torn in numerous places.
Its the seal thats attached to the body of the car not the actual one on the door. Its on the driver side.
I've tried to find the part online and can not find it anywhere.
Could anyone help or would of these work.
SEAT Rule
188
62
Hello there,
I think possibly you're talking about the door aperture rubber seal, that's attached to the car body door frame, I think I've found the part on Etka.
There's at least 3 options listed per side so depends if yours is rubber on the inside edge or fabric lined/covered,
plus if it's a saloon or estate model ?
Also the part number might be written on your old rubber seal in white or possibly yellow writing, on the inside edge facing the interior ?
Also there might be a slight difference in colours from grey to black or satin black ? Hence the different parts numbers listed below.
Front LEFT aperture door frame seal
Part number 5JA 867 365C or 5JA 867 365E or 5JA 867 365G
Plus can have 5AP on the end of above part numbers for black.
Front RIGHT aperture door frame seal
Part number 5JA 867 366C or 5JA 867 366E or 5JA 867 366G
Rear LEFT aperture door frame seal
Part number 5JA 867 367C or 5JA 867 367E or 5JA 867 367G
Rear RIGHT aperture door frame seal
Part number 5JA 867 368C or 5JA 867 368E or 5JA 867 368G
Boot aperture rubber seal
Part number 5JA 827 705G
from early 2013 to early 2015
Price wise these aperture rubber seals could range from £80 to £130 per each ??
You'll have to contact your local SEAT main dealership for price and availability, plus they'll confirm which part number is correct for your car, if you give them your Vin/chassis number or registration number.
Hope this helps
Si
