2014 Ibiza Cupra 6J
harry123
35
Hi Guys,
First post and new to the Seat group.
Recently purchased a Ibiza Cupra which had few bulbs out before i bought it, light was on dash, didn't think much.
Now i am unable to get the number plate bulbs to work. Currently has led festoon type bulbs, both which i know work because i put them in the central light and they came on. problem is when they in the number plate light they do not work.
tried the usual banging around the area, removing putting back in but no luck.
Also tried a normal festoon and had no luck with that.
The list bulb casing comes out as a whole so theres no wires dangling when changing the bulb (if that makes sense)
Hoping someone has had a similar issues or know what may be causing the problem.
Thank you in advance. :)
Legojon
I only wanted a remap
5,284
2,714
Welcome. If both number plate bulb fittings are out, I'd check the fuse next.
