What side does the 'in' pipe attach to?
The baffled side or non baffled side?
That is all
Cheers Rich
I fitted the catch tank at the weekend and all went well. But something has sprung to mind.
The puc.
I cleaned mine out as it was full of gunk and refitted it.
What does it do because its just dawned on me that there were "workings" inside. Is it a 1 way valve? Should it hold pressure?
What happens if it doesn't work?
It was an original part so maybe i should replace it.
Rich
I now feel the urge to check mine lol, ill add it to the listThink ill replace it. Been on there almost 17 years now.
Was doing a little work on the car thismorning.
Thought id check inside the catch tank.
Was damn near half full (well between 1/3 & 1/2) of water!
2 weeks and just shy of 300 miles. Does that sound right?
No funk on the filler cap when i looked when there used to be a little pre catch tank.
So i guess its working correctly and "touch wood" dont believe it has head gasget issues.
Rich
Good to know it isnt just mine then. Will check it every 2nd week then.
Better out than in
Not an issue with a vent to atmosphere ....the water sits on top and if it gets too full is just dumped out and not into the engine
