AGU head query...
285cupra-matty
488
Harlow
hi Guy's,
i am after a bit of info on the AGU head.
basically long story short, i am making my LCR 4wd in a few months or so got all the bits sitting there waiting. i also managed to pick up an AGU head cheap, in mint condition :).
my plans for the car are the above mentioned 4wd and a full engine rebuild i.e pistons, rods, fuel rail, bigger injectors, baffled sump, new oil pump new shells, bearings, lightened crank, GT3071r twin scroll or GTX3071r (not sure which one yet again if anyone has info that would be great) with tubular mani etc etc.
so my question basically is does a AGU head work on a BAM engine, my friend seems to think that AGU engines dont have vvt so the head wont work, but im under the impression that the vvt is interchangable between heads (please correct me if im wrong). so plan being if i can use the head would be have it gas flowed and new cams, valves, and all the other gubins that go with cams and valves.
bearing in mind there maybe a posibility it will be happy gased after :). for that little extra bit of poke :)
i am aiming for 475 - 500 hp without :happy: gas
any info would be deeply appreciated.
Dec 25, 2009
1,531
Yes it has been done in the past, it was done in a Purple small bumpered MK2 Golf with Rallye front, not 100% sure of full spec though
