you cant unless you get some speakers that make the chatter for you, induction kit get a BMC CDA or dynatwist or ramair.
Get a Forge coldside DV relocation kit and then fit it incorrectly, thats what I did, LOL. I basically blocked off the wrong pipe, I wouldn't recommend it, I've heard its VERY bad for the turbo.
wastegate chatter is a sign of a non functioning DV which is bad cos the compressor tries to stall on closed throttle without any venting.
Bill, have you had any probs with people getting chatter after fitting the Forge DV relocation kit? I have fitted it correctly now and it still sounds like there is a slight chatter when lifting off of full throttle. I can only hear it if I have all the windows closed and if I didn't have the induction kit I don't think I would hear it at all.
I had a slight chatter when my car was reporting a duff N249 - turned out to be a split pipe, the one that leads from the N249 to the top of the DV. It had split on the Y piece just after the N249.
Take the engine cover off and it's at the front right of the engine.
i have heard people report this before, but I have'nt fitted one myself.
I don't suppose you have any pix, with the N249 circled, so I can see exactly what it is do you? I don't know what I'm looking at :(
I have moved the DV back to where it originally was, but am still using the cooler air from the intercooler. I thought this would fix the problem, but it hasn't, I can still here a slight chatter noise, especially if i blip the throttle and let off again :(
