airfilter change leon cupra
DAZFR72
279
In The Van
Guys needing some advice, how the hell do you remove the engine cover to change the air filter, simple question i know, i have un clipped all i can see and pulled like :censored: on the cover without it moving !!!
Thanks for help
Seat racer
vagcom owner
Jun 7, 2012
288
renfrewshire
Youve gotta be forcefull m8, itll go with a bit of brute
Strength, start at the front left side, ive found that once
1 side frees off the rest are easy as not under tension,
When refitting cover make sure you grease the rubbers
And fitting clips, makes future removal a cinch.
vincent5525
Mechanic
Jul 2, 2011
267
uk, sheffield
DAZFR72
279
In The Van
Thanks guys for advice by golly they designed the rubber seals well twas like a major tugg trying to get the housing off !!
