Aktive subwoofer
Apr 8, 2021
Did Anybody Installed A Pioneer Active Underseat subwoofer In there Leon?
Should I connect It to front or rear speakers wires, i use the high to low converter I for with It?
And should i ude Vcds to code It with, so I can control the sub direct from the radio sound settings?
Walone
1,548
426
Near Heathrow
VCDS will not do the coding for Sub menu, I'm sure several members have fitted active subs but connections will mainly depend on the MIB unit and speaker setup that you have in your car, the outputs on the rear vary slightly.
Apr 8, 2021
I have A Mib2 with navi and 8 speakers/discants so I have to connect It to two rear speakers instead of the front i use now?
Walone
1,548
426
Near Heathrow
