Arb removal
diponio24
71
Hey guys looking for some advice on how to remove the arb on a mk1 leon cupra can it be taken out through one of the sides or does it have to come underneath the car.... Can seem to find much info on it as you can see the car is lowerd and rubs a little on full lock
Sent from my PRA-LX1 using Tapatalk
Dazzalcr
235
185
As said above you do have to drop your sub frame a little, I found it a pain in the arse when i upgraded my arb, you have a good day for it though. Nice motor them bolas look good on it as well.
diponio24
71
Thanks and yeah I'll have a bash at some point
diponio24
71
Oh and the wheels are rota grids.. 9.5j at the back and 8.5j on the front with a 15mm spacer
Connor H
1,014
498
Essex
I w
Was thinking about some 9.5j for the rear in the future, good to know they fit. What tyre you running?
diponio24
71
It's a 225/40/18 all round got a little big of stretch on the back but fit fine looks wide form the rear
Reactions: Connor H
Yellow fr
Sep 6, 2018
1,547
1,062
Sandbeds West Yorkshire
It can be done you will need to remove all subframe bolts and drop links the two rank bolts and remove drivers side drive shaft and the 3 bolts for the ball joint and the remove the dog bone mount then remove the bolts for the anti roll bar and work it out a bit off a fiddle or what I would just do is remove the both ball joints from the lower arms the 3 bolts the two from the rank the dog bone and the subframe bolts and then drop the frame down and out take off the old and put in the new then refit a bit easier and maybe quicker and less hassle
