Hi All,
So went and got my dpf removed and stage 2 remap, dyno had a read of 207bhp from 165 so quite impressed.However just prior to having it done the guys at NV too a diagnostic and got the following errors, they state these arent serious which i looking at some navigate ie i can see there pojnt, however can anyone advise if any of the below could cause future issues?
01-Engine -- Status: Malfunction 0010 (presume this is resolved now dpf removed and didnt come up again)
37-Navigation -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-018-BMN.clb
Control Module Part Number: 03G 906 018 DT HW: 03G 906 018 DT
Component and/or Version: R4 2.0l PPD1.2 G 4352
Software Coding: 0050072
Work Shop Code: WSC 02108 210 95594
VCID: 7AF1B07B35E0CDCED53-802F
2 Faults Found:
012600 - Intake Manifold Runner Control
P3138 - 006 - Regulation Deviation - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 5
Fault Frequency: 5
Reset counter: 40
Mileage: 145530 km
Time Indication: 0
Date: 2000.00.00
Time: 09:52:48
Freeze Frame:
RPM: 2816 /min
Torque: 16.0 Nm
Speed: 90.0 km/h
Mass Air / Rev.: 724.9 mg/str
Lambda: -22.7 %
Text: Kein Messwert verfuegbar
008194 - Particulate Trap Bank 1
P2002 - 006 - Efficiency Below Threshold - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 5
Fault Frequency: 7
Reset counter: 40
Mileage: 145718 km
Time Indication: 0
Date: 2000.00.00
Time: 15:03:44
Freeze Frame:
RPM: 1152 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
(no units): 0.0
Lambda: 102.4 %
Pressure: 0.0 mbar
Time: 0.0 s
Readiness: N/A
Address 01: DTCs cleared
Address 01: Engine (03G 906 018 DT)
10:29:25 Group 070: Particle Filter (Regeneration Status II)
00000000 Status 4 Regeneration
1.0 s Regeneration Time (Total)
0.0 Failed Regenerations
0.0 Successful Regenerations
10:29:25 Group 075: Particle Filter (Exhaust Gas IV)
128.1°C Temperature bef. Turbo Charger
89.1°C Temperature bef. Particle Filter
103.1 % Particle Filter Load Coefficient
58.5°C Temperature after Particle Filter
10:29:25 Group 003: Exhaust Gas Recirculation (EGR)
789 /min Engine Speed (G28)
260.0 mg/str Exhaust Gas Recirculat. (spec.)
266.7 mg/str Exhaust Gas Recirculat. (actual)
58.5 % Exhaust Gas Recirc. Duty Cycle
Address 37: Navigation Labels: 1T0-035-680.clb
Control Module Part Number: 1T0 035 680 L HW: 1T0 035 680 C
Component and/or Version: RNS-MID H11 5230
Software Coding: 06000402040000210000
Work Shop Code: WSC 00000 000 00000
VCID: 3777694F867210A66AD-8062
2 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 68
Reset counter: 181
Mileage: 145024 km
Time Indication: 0
Date: 2000.00.00
Time: 11:46:47
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 163
Reset counter: 181
Mileage: 145024 km
Time Indication: 0
Date: 2000.00.00
Time: 11:46:55
Address 37: DTCs cleared
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Control Module Part Number: 1K0 959 433 BT HW: 1K0 959 433 BT
Component and/or Version: KSG PQ35 G2 020 0203
Software Coding: 988000005283CC7F0006050560085F86107C00
Work Shop Code: WSC 54872 001 1048576
Additional Info: 1K0951605C LIN BACKUP HORN H03 1301 NGS n.mounted
Additional Info: 1P0951171 Innenraumueberw.010 4971
VCID: 830F4D9FC22A0C06065-80D6
2 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 5
Reset counter: 211
Time Indication: 0
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 211
Mileage: 145456 km
Time Indication: 0
Date: 2000.00.00
Time: 18:24:06
Address 46: DTCs cleared
Address 56: Radio Labels: 1T0-035-680.clb
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 145760 km
Time Indication: 0
Date: 2000.00.00
Time: 10:29:38
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 145760 km
Time Indication: 0
Date: 2000.00.00
Time: 10:29:42
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 145764 km
Time Indication: 0
Date: 2000.00.00
Time: 10:29:37
Address 56: DTCs cleared
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 40
Mileage: 145530 km
Time Indication: 0
Date: 2000.00.00
Time: 09:52:48
Freeze Frame:
RPM: 2816 /min
Torque: 16.0 Nm
Speed: 90.0 km/h
Lambda: -22.7 %
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 40
Mileage: 145718 km
Time Indication: 0
Date: 2000.00.00
Time: 15:03:44
Freeze Frame:
RPM: 1152 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
(no units): 0.0
Lambda: 102.4 %
Pressure: 0.0 mbar
Time: 0.0 s
Readiness: N/A
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 68
Reset counter: 181
Mileage: 145024 km
Time Indication: 0
Date: 2000.00.00
Time: 11:46:47
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 181
Mileage: 145024 km
Time Indication: 0
Date: 2000.00.00
Time: 11:46:55
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 211
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 211
Mileage: 145456 km
Time Indication: 0
Date: 2000.00.00
Time: 18:24:06
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 145760 km
Time Indication: 0
Date: 2000.00.00
Time: 10:29:38
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 145760 km
Time Indication: 0
Date: 2000.00.00
Time: 10:29:42
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 145764 km
Time Indication: 0
Date: 2000.00.00
Time: 10:29:37
