ARL camshaft
SteveWM
152
47
West Midalnds
Finally got round to investigating why the 2005 FR Leon was running so badly, severe camshaft wear, sounded awful and drove like it was on 3 cylinders. As you can see 2 holed and 3 dished tappers. Also reckon lobs 1 and 8 must have worn away by 1/16th of an inch easy.
Anyway, new camshaft is in just need to torque it all up and reassemble. Only tools I had to get were the timing locking set. Not a particularly hard job although I bet some of the bots could be a bugger to sort if seized.
Reactions: Andrewwright
SteveWM
152
47
West Midalnds
By way of an update, apart from a faulty cam bearing shell bolt (new) snapping off in the head the car is back together and sounding better than it ever has.
Took a few good cranks to push the oil into the tappets but fired up a treat.
After clearing up I measured the old cam lobs, from one that showed no sign of wear to lob 1 and 8, 4mm difference! No wonder it didn’t run right, amazed it ran at all.
With a bit of time and thought a job easily tackled if you’re OK with the spanner’s. Special tools for the timing £25 and did the job perfectly.
