arosa 1.0L gearbox removal
thevanwizard
I have just aquired an arosa that needs a new gear box.
i have also aquired an accident damaged arosa with a very good gearbox so im in the process of swapping them over and having a bit of a nightmare.
I have removed both drive shafts starter motor and all the bolts i can see that hold it in position , so lowered it on the jack adn it wont come away from the engine been on it now for a day and a half any ideas guys all i can see is one bolt left that is just below starter motor goes th a bar that is conected to body where gear selector cables come through undone the top nut but there is another nut just above drive shaft does this need to come of as thats all i can see could be holding it on :cry:
thevanwizard
whhaaayyyy its out now on to removing the other :clap:
happy days :funk:
ianswebb
Just had the exact same problem removing the box from my 1.4.. such a pain in the arse. Wrestled with it for a
good hour prior to finding it, then ran out of light. So its still attached :mad:
Ian
