i was having trouble with my ibiza;s boost early in the week wen it was only boosting 10-12psi instead of around 18psi. It was put on a VAG-COM and found that it was mostley my MAF sensor that was toasted and not working properly(as i found it was a comman fault)
and so i ordered a new part.
after fitting the new part disconnecting the battery for a while, there was absoulely no boost, 1-2psi if any, also i have the APR sofwear on my car and the cruise control button than operates it wil not ingage the software but the cruise control will work, this all was working until the maf sensor was fitted today. I then had it on the VAG-COM today and i was told it looked like it was in limp mode by philw. He will be posting the fault codes and the VAG-COM readout when he gets back. I have tried unpluging the maf sensor to see if it will run better but it is exactly the same.
any help will be much apprieated thanks
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
