Where the programmable side, rely mostly on menu toggling, has it's uses via Obdeleven Android as an alternative or VCDS. My understanding is Carista is app driven like the bog standard Obdeleven, the Pro version of Obdeleven unlocks the programmable side of Obdeleven. That's where the differences between the two kick in except one is Android based the other iPhone. You just buy a cheap Android device if you dont have Android. You then just turn published VCDS into Obdeleven. That's where you see some jokers publishing the VCDS stuff on Obdeleven threads but not how to turn that into Obdeleven commands... probably because they dont know how.
That's where you sometimes have to do some puzzling if you can't find an example.
I did assemble some Ateca ones with examples which I did on mine.
