Clutch Pedal Material>>>
R53Winny
91
34
Survey Question = Post below whether you have a metal or plastic clutch pedal and year of your car. 🤔👍
Reason for Question = I had a new Clutch Master Cylinder + Uprated Pedal Assembly installed under warranty in December on my 2017 FR. My pedal is now plastic and I can't remember whether it was metal before 🤔🫴
Note: All other pedals are metal ®️
SuperV8
1,872
941
Clutch pedals are dependent on which gearbox you have.
My MQ350 = 5Q2721059HD = plastic!
You'll also have a plastic accelerator pedal.
Brake pedal is metal as it has the potential to see much more load in an emergency stop.
Reactions: R53Winny
R53Winny
91
34
Does the vehicle age determine the type of gearbox or is it more vehicle model?
I had an uprated/new design clutch pedal assembly fitted when I had a new master cylinder fitted but can't remember what the pedal was made of before! 🤔
SuperV8
1,872
941
The engine determines the gearbox. The MQ350 is the gearbox fitted to the 2.0 diesels and Curpa's etc.. so the strongest manual box, so would have though if that version has a plastic clutch pedal the smaller boxes will certainly have a plastic pedal.
What's your car & what year?
Reactions: R53Winny
R53Winny
91
34
Seat Leon FR 150BHP MK3 2017 early facelift
SuperV8
1,872
941
On 19.04.2016 there is a change - pre this date then my comments above apply, so 3 different clutch mechanisms depending on gearbox, master cylinder comes with the pedal assembly.
After this date they list the master cyl and pedal separately - and now with no gearbox differentiator - just LH and RH versions!
Your clutch pedal is 5Q2721321D
Either way, still a plastic clutch pedal.
As the master cylinder is available separately - don't know why they are also changed your pedal?
Reactions: R53Winny
R53Winny
91
34
Thanks very useful information. They changed my pedal assembly saying there was a design flaw in the old and fitted an uprated version!
