i find its usually the middle one
There have been a number of revisions to spec, dealers will give you the latest one so it should be the most reliable. I buy mine second hand so expect them to fail at some point.is there any upgrade for them, say the 1s from a 225 or newer model that are more reliable or is it just something u have to put up with??ta
a coil pack, is a coil. It takes the 12 volt supply and converts it to higher voltage for the spark plugs.
Traditionally cars had 1 or 2 for the engine and then HT leads to take the power to the spark plugs.
On the 1.8T there is a 'coil pack' for each spark plug. They fit onto the end of the spark plug.
