Controls Help.
Roachy23
Speed Blue
May 30, 2012
21
Essex
Hi, i have recently purchased a Seat ibiza cupra 2010 plate, and have a few questions about the controls as i havent got a manual and cant find one online.
Ive tried looking through previous threads but cant seem to find what im after.
1) With the radio how do i save radio stations?
2) Do i have to have the wipers on a certain setting for the automatic wipers to work?
3) Can i play music through bluetooth?
4) Also on the display where it tells you your average MPG and the time and stuff, what is the one after the display that tells you how much miles youve got before you need to fill up mines says 205. the one after says 303 Miles though?
Sorry these are stupid questions i upgraded from a 1999 rover 25 so you can tell the technology has changed alot.
nightflight
2,677
13
Sheffield
1.
2.
3. yes but it involves some fiddling with vagcom if i remember correctly?
4. If you're going "down" through the readouts the one after "miles left" is "miles covered this trip" if you look up and right of the big number there'll be a 1 or a 2.
If it's a 1, the big number resets automatically;
after 2000 miles (i think it's 2000? can someone confirm), OR
once the engine has been turned off for 2 or 3 hours OR
after the engine has been running for something like 19 hours (again, i think, can someone confirm?)
OR
you can reset it manually by pressing and holding the round button under the stalk for 2-3 seconds.
If you press the button under the stalk briefly the little number will change to a 2 (or a 1 if it was on a 2)
If the little number is 2, the value doesn't auto reset and will keep clocking up until you manually reset it using the button under the stalk.
There are a few readings which have a 1 or 2 option...
MPG, Miles covered, average speed, time of journey.
hodson
89
Staffordshire
For the wipers you just push it up once and then adjust the little thing ontop of the stick for how sensative you want it =]
nightflight
2,677
13
Sheffield
re radio:
1. tune the radio to the frequency you want to store.
2. in the top left and top right corners of the screen will be two different words, one will be memory (the other is manual i think?)
3. whichever side of the display "memory" is on (left or right) press the button on the corresponding side of the volume dial.
4. use the volume dial to select which memory position you want to store the station on.
5. press and hold the volume dial in for 2-3 seconds until it beeps at you.
