cool problem
Oct 12, 2005
1,013
i dunno if this is a probelem or not but when i put on the airconditioning the snowflake icon comes on for bout a second then goes off on my leon fr tdi. IE when u press the button to put the air on the front windowscreen the airconditioing used to come on....now it doesnt.
Also y does the turbo whistle always sound different. sometimes its loud n sometimes its quiet
THANKS
Pabs
5,936
Basingstoke
right mate, before u get flamed on here, the search button would DEFINATELY reveal the answer to your first question.
In fact, your leon car manual will also answer your question.
Because I am a nice guy, i will answer anyway - the aircon does not operate when the outside temperature is below a set level - usually around 5 degrees or below. (not entirely sure as i dont have my manual with me) In the weather we have at the moment this would explain your problem...
Turbo whistle sounding loud and sometimes quiet? This is bound to be down to circumstance. Road noise varies from road to road, weather and temperature, in fact climate you are in will also affect this in two ways - one of which is probably because your car is running on cooler air (bit of a guess)
the other reason i could think of, could be one time u listen with the window down, the next time u dont :bleh:
HTH mate.
CupraUK
Pushing on
Aug 15, 2005
1,350
Bedfordshire
Erratic turbo whistle could be loose connection on N75. Mine was, sometimes boosting properly other times hardly any boost at all. Pushed the connector on properly and things were sweet again.
matt_s
4 8 15 16 23 42
Dec 23, 2004
657
19
Don't know what the manual says but mine goes off at 2 deg C. When I get the car out and drive to work the measured temp drops so I've noticed when it goes off.
CupraUK
Pushing on
Aug 15, 2005
1,350
Bedfordshire
At the top of the engine cover on the right. Black connector block going into it and a couple of vacum tubes. about 1/2 inch big.
