Cordoba Starting
shiller1984
More often than not when i try to start the car it takes a couple of attempts.
When i turn the key nothing happens - if i turn back off and try again it will start.
Is the starter motor causing this? Does it mean i need a whole new starter motor or is the one bit on it i can replace?
Does anyone have the part codes for the motor and/or any other bit that needs replacing? whether it be Volkswagen/seat etc
Its a Cordoba 1.6 SX AFT engine
Thanks in advance for your help, its getting annoying now as i keep putting the alarm in programming mode.
Simon
shiller1984
anyone?
its getting worse now so need to get it sorted asap
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
Can you hear the starter motor turning on the first turn of the keys or is it dead? If its dead it could either be the starter or a tempermental ignition switch, The starter on my 1.4 Ibiza failed and that was £100 fitted, however mine didnt just stop it got weaker as time went on.
shiller1984
its dead unfortunately just need the part number so can order the new one anyone know what it is or where it should be on the motor?
