Found this topic when searching for "tyre-pressure" with Google.
Been busy with calculating it with use of the formula, the European Tyre- and car- manufacturers also use to make the advice -stikkers on cars, so reliable.
Learned myself Excell to make spreadsheets for it.
Last one I translated to English from my native language Dutch ( so sorry for mis-spellings and wrong words).
cid-a526e0eee092e6dc.skydrive.live.com/browse.aspx/.Public/Recalculating%20tyre-pressure
copy and paste this to your browser, the http thing places itself, I can not post links on my first post.
in this map always take the newest version, and there is an Example with 2 pictures of it.
Is just what you need, for re-calculating tyre-pressure advice when other then original tyres are placed. Can also be used to check the original and see if you can go lower in sertain conditions.
I also would expect a higher pressure in front then in rear, but normal load-advices are seldomly given nowadayst ( tree puppets and al little trunc on the symbol) what you read of the stikker now is that for what I call Heavy load or vacation load in my spreadsheet, where the load on the back is higher so pressure advice back higher.
If you cant work with it , give me here the needed data ,wich are on the first apearing screen when you open the spreadsheet, and I will use it as an example here.
Made more spreadsheets and also translated a few, you can navigate my complete public map from this link to find them.
