I don't know what it is but it's a common issue. My car does it. I put it into the dealer a couple of times while it was under warranty but they said they couldn't find anything, surprize surprize. Personally, I think it's the plastic covers on the rear dampers but that's a guess.
I believe most cars now do this, it's usually the wishbone/control arm bushes, as long as it's only a minor creak every now and then, nothing to worry about.... if it turns in to a knocking noise, then something needs to be done.
Obviously I havnt heard it, but this seems to me the most likely cause
If it is the plastic covers, can these be removed to remedy the situation?
What area of the car are the creaks coming from? I have a 16 plate FR SC and the whole car felt like it was creaking when reversing up my driveway. Found it to be the rubber seals on each door. Cleaned the rubbers using Autoglym vinyl and rubber care a few weeks ago and problem solved so farHi guys, my14 Fr 184 keep getting a creaking noise when I go over speed humps, it’s not noticeable over bumpy roads, but very loud over humps. Any ideas what it could be?
Doesn’t sound like the same noise then, good luck finding the source, creaks drive me crazy!It’s from the back, and it seems like it’s coming from the suspension
I hoped Seat will push new part with better material quality..
Did you ever resolve this?
