Corrected hp
Hi Andrew, as posted under another thread, my car came back with 239.6bhp (242.9PS) at the wheels and 288.6 bhp at the fly (292PS)@ 5848rpm. torque 256.98/284.82 @3173rpm I'm unsure about the correction calculation, how does that work or how do you calculate it? Does this mean with the corrected figure that mine is approximately approaching the 318 you got? The temp was 18.6 degrees, humidity 61.8% pressure 999.2 mb, height 129.143m. do you have a link to an online calculator or an equation?
I found an online calculator which gave the following:
Horsepower : 288.6 uncorrected
Station Pressure : 29.51 (in/Hg)
Temperature : 65.48 (° F)
Relative Humidity : 61.8 (%)
Correction Factor Horsepower
DIN 1.011 291.85 (295.90 PS)
J607 1.022 294.93 (299.02 PS)
J1349 (SAE) 0.992 286.27 (
290.24 PS)
STD 1.016 293.28 (297.35 PS)
Uncorrected 1.000 288.60 (292.60 PS)
So, with all of these different corrections, which is likely to be the most accurate?
Edit: I've read that SAE figures aren't relevant for Turbocharged cars.
Edit 2: The temperature used was ambient in the garage 18.6 degrees centigrade/65.48 degrees F. I'd suspect that is artificially low and therefore would produce an under-reading? What sort of uplift over ambient would be more accurate for inlet temperature, considering the
Cupra engine seems to run quite hot. I know it's fresh air coming in, but even in tha short distance there is bound to be an uplift of some description.
