You want the 'Fan' spray nozzles, if yours are UNheated then the VW part number is 5M0-955-985-C-9B9, the 0 is a zero. If you have the winter pack it will have heated jets, not sure what the VW number is but it's close to the number quoted. There are lots of fake/cheap ones on eBay some are reasonable quality others not so good.
Look here: guides sections pinned to top of forum. As above, fan jets is what you require; two types, heated and standard, depending on if you have the winter pack option (heated seats, heated washer nozzles, headlight washers).
Installing Fan washers
Guide now located in the new resources section of the site https://www.seatcupra.net/forums/resources/installing-fan-washers.21/www.seatcupra.net
They will fit but won't heat. Surprised you could not find non-heated ones, also the heated ones are usually much dearer.Thanks all for your input.
I couldn’t find non heated so ordered some heated ones, however I don’t have the winter pack (I don’t think). Will that matter? ie will the hearing bit just not work?
Thanks for the clarification. Heated were only £12 for the pairThey will fit but won't heat. Surprised you could not find non-heated ones, also the heated ones are usually much dearer.
12 pound. Here in the uk the standard unheated ones are 10 pounds each and they are cheap copies?. Where you get them fromThanks for the clarification. Heated were only £12 for the pa
EBay. Watch this space.12 pound. Here in the uk the standard unheated ones are 10 pounds each and they are cheap copies?. Where you get them from
