Cupra Formentor underbody protection?
Jun 7, 2022
10
Good morning,
Does the Cupra Formentor have some sort of underbody protection at the front and back? Its 4drive system seems to be similar to the one on the Cupra Ateca, but there's a slightly lower ground clearance, so I'm wondering if there's some sort of underbody protection in it, in case things go wrong in dirt roads with big holes? If not, do you think there's a possibility to install it through aftermarket parts?
Thanks!
Ninjakebab
176
91
Not sure if the 4WD versions are different, but the FWD Hybrid just has plastic covers all the way under it - not much real protection I guess, but the ground clearance is quite a bit taller than standard cars.
