Hello, I'm thinking of buying a
cupra r 2011 35k miles,
Is there any issues or problems i should look out for.
Over and above normal issues with used cars check bonnet lining, goes mouldy due to poor bonnet/panel joint, several threads on here about that. Check wheels and tyres, the 35 profile tyres are prone to pot hole damage, wheels can be buckled too. Check wear on inside of rear's , if tyres have 'saw tooth ' type wear on them car will be noisy ( sounds like worn wheel bearing) and will need 4 wheel alignment . Side bolsters on front seats have been an issue on some. If you know the reg of the car you are looking at might be worth posting on here, someone may know it and the history.
Do some searches on here, there are a few threads about common Leon issues , over and above what I've mentioned above.
