Hi folks from a newbie,has anyone managed to wire up a dashcam to a switched feed and if so how.My passat was easy to do as the fuse box was just under the dash,thanks.
My dashcam is powered from the OVD socket. It’s a switched unit that allows recording when parked and has a cut off so that it doesn’t take excessive power from the battery.
That may be an option.Mine is a Mio with sat nav and the consumptions quite high and blew a normal dc to usb adaptor in a couple of days.Is the Halford one the normal mini usb type,I couldn't see any rating on it so it may only be suitable for the Black vue.
Now I have had time to have a good nosey I have found a convenient tap off point in the fuse box under the dash so all sorted without any outlay,thanks for all suggestions.
