Hi all, I am looking at buying a dash cam for my 2016 Leon FR. Are they fairly easy to hard wire in etc.
Guest - you can now get 20% off all AutoBrite detailing products!
Exclusive SCN members only discount thanks to APAutostyling
Hardest bit about hardwiring a Dashcam Inn is rotting the cabling. If you follow the guide shown above it’s fairly straightforward to write in.Hi all, I am looking at buying a dash cam for my 2016 Leon FR. Are they fairly easy to hard wire in etc.
I found the hardest bit with mine, (i have the rear facing camera as well) was getting 3 PHAT wires into the A-pillar trim.Hardest bit about hardwiring a Dashcam Inn is rotting the cabling. If you follow the guide shown above it’s fairly straightforward to write in.
A-Pillar trim was definitely a right PITA when I did mine, and I only had one cable to get in there!I found the hardest bit with mine, (i have the rear facing camera as well) was getting 3 PHAT wires into the A-pillar trim.
Really easy. I fitted a Garmin 66w with no previous experience. The cable fits nicely around the top of the windscreen down to the glovebox where the fusebox is. I used the internal light fuse connection for permanently on power and the cigarette lighter fuse for the ignition switched power. I picked these for their minimal impact if something goes wrong on those circuits.Hi all, I am looking at buying a dash cam for my 2016 Leon FR. Are they fairly easy to hard wire in etc.
