de-wiper
dg-1984
254
Glasgow'ish
I think he means just remove the rear wiper!!
Need to remove the rear plastic cover in the boot so can get to the motor, remove the rear arm, then undo the motor from the rear panel, will have to get a rubber bung to cover the hole, I am unsure on how to remove the cover and also dont know the part number for rubber bung.
Not much help but thats the idea.
b1nuzz
271
Bristol
Surely that isn't a good idea?
The rear window collects water because of the angle its at. Hence the wiper.
If it didn't need one, it wouldn't be on there..
Just change it for a fabia wiper.. That will look better than no wiper :)
Skint
Because i'm worthless..
Dec 7, 2008
92
On the A281
To be honest I think you will not have too many problems with visibility, how often do you really need to see clearly through the back window?
The bungs you need you can get from halfords, get a pack of mixed size blanking gromets and one of them will fit. Should set you back about 70p.
tgorman
LCR = 285Bhp + 330Ft.lbs
Jul 22, 2009
91
get one from gecleant.de they sell glass ones
look so much better than the rubber bungs
