Disc locator screw - help...
bumblingfool
Just Another Number...
Nov 26, 2004
64
Lincoln
Hi guys, just been doing my rear brakes and the locator screw on the disc was well stuck and i ended up rounding off the head. I therefore took to drilling it out which went ok except for the fact that ive damaged the thread in the hub. Has anyone else been stupid enough to do this and what can i do to resolve it? Obviously i can buy a new hub but i dont have the £cash
My nice new discs n pads are waiting for this one stupid little screw!!!
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
how hard did you drill it lol
You don't need the retaining screw (you have 5big M14 bolts instead...)
bumblingfool
Nov 26, 2004
64
Lincoln
pretty hard cos i've just fitted a koni sport suspension kit so i was a bit miffed with a little screw getting in my way, i know that the retainer isnt vital but when i try to put the wheel on it moves the holes out of line (i dont have a gentle touch). Just wondered if i can re-thread it or somethin cos i like stuff to be right, oh yeah and i wanna be able to screw up my tyres....:D
Steamy
80
Scotland
One thing you could do is fit an insert called a "Helicoil".
Fitting this involves drilling the hole out to a larger diameter and then threading it with a tap. You then screw the helicoil into the enlarged hole and the inside of the insert is hollow and threaded to take the original screw.
Only problem is I don't think many garages will have the kit to do this but I would imagine almost any engineering shop would be able to do it for you.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
but that'll cost a lot more than a new hub all told?
You need to drill and use a reverse tap for the left over stud - then run a tap through the left overs of the thread
don't waste too much time & effort on it though - just me more gentle (or if you apply the handbrake when jacking the disc won't move
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Just ring round for engineering places that do helicoils (like m0rk says the sets are ****ing expensive, good though).
Or get one of those wheel aligning tools (or an M14 Bolt with the head cut off) screw it in one of the stud holes, it'll keep the disc lined up while you put four of the studs in, then remove it and put the fifth in.
bumblingfool
Nov 26, 2004
64
Lincoln
yeah i managed to get the wheels on by applying the handbrake, why didnt i think of that :doh:
will look at all the options, i rekon i'll find a local engineering place and ask em what they think...
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
First of all, try rethreading the hole with a tap. Unfortunately I don't know what thread is appropriate, but if there's any metal left you should be able to get sufficient thread to hold the disk on while the wheel is heaved into place.
The little screw is only there to hold the disk in alignment. If there isn't enough metal to form a thread, get a new screw and stick it in place with something like Loctite or Bostik :rolleyes: It isn't load-bearing, after all. The wheel bolts take all the load.
