Hi everyone. please can anyone help me get the part number for the screw that locks the door handle housing
Hello there,
I've had a quick look on SEAT Etka but can't see any screw for the exterior door handle for the MK4 Ibiza, the only screws I can see on the MK4 are listed below.
MK4 Ibiza
Door catch screw
Part number N90 800 503
M8 X 14mm Torx head
MK4 Ibiza
Exterior door handle inner adapter plate
Part number N90 897 601
M5 X 9.5mm Torx head
The above exterior door handles on the MK4 and Mk5 Ibiza's normally have a rubber grommet you have to pull out, and use a hook stem tool to pull back the plastic retaining clip, that basically holds/secures the door handle.
But on the MK3 Ibiza it looks like they do use a small torx head screw to secure the exterior door handle, as you've shown in your photo a handle that is held in place this way, my guess is your Ibiza is a MK3 ?
MK3 Ibiza
Part number N90 598 804
M6 X 12mm Torx screw
But as Mr Syphon has already advised it's best to ask Andrew from Listers, who is one of the Forum parts sponsor's I think.
Hope this helps
Si
I think you nailed it my friend. thanks! yes I am guessing it is called mk3 at your region, the year make is 2003, it is also called mk4 in some listings.
how did you find it? cause in the car blue prints online they don't mention this screw that is beneath the plastic screw cover..
So I fount the screw when I opened the door card etc. and apparently it is an M4 flat head ~22-25mm. screwing it back was also tricky asside from it being deep and wanting to fall into the door each time (I used a paper tape) you also need to make sure to insert the screw and hold the latch over it.. (better to look at other doors for refference)Hello there,
MK4 Ibiza
Door catch screw
M8 X 14mm Torx head
MK4 Ibiza
MK3 Ibiza
Hope this helps
Si
