Door handle rattle
Oct 12, 2005
1,013
I have a rattle on the passenger side inside door hanle. I am not with the car at the moment. Was just wondering if its easy to pull apart. The rattle is more evident when you squeze the handle.
BlackFR
1,727
7
Not too far away
Very easy to pull that section apart. It all just unscrews or levers apart...
I had the same rattle traced it down to just behind the door release lever. I just used P profile draft excluder on the mating surfaces of the plastics to stop the rattle:)
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
door card will need to come off but its only a few screws then ul see the handle mechanism the cable is tapping against the door membrane a bit of foam or sponge between the two will stop that mate!
the handle itself doesnt unscrew or leaver apart its part of the doorcard so dont try that :)
