downpipe and decat quick question
casper20v
127
Just recivied my new 3" down pipe and de cat and my o2 spacer my question is I have two bolt holes for it to go on one on downpipe and one on decat witch one do I use?
steveturbo
71
Have you bought the one off eBay £110 I think it is?
Any good?
Also you got a link to the spacer you used?
Cheers :)
leighwinter
239
Could you put the lambda in the decat pipe and use the first hole closest to the turbo for an afr guage
pazz1991
260
why is there two holes on the down pipe and decat , i have just bought the one off ebay , and now i see you need a space , i was hoping to fit on sunday ?
casper20v
127
Not fitted it yet but looks good quality. And u need a spacer to stop engine managment light comin on. I just typed in lamba spacer on ebay and it came up 9quid included postage bargain!
Apr 15, 2009
2,189
Midlands
Wouldnt work as the pre-cat lambda needs to be in the first hole
You can use the hole for the second sensor (have second sensor mapped out) for afr gauge but it wouldnt be as accurate readings as its too far down the pipe.
Best bet would be to have an extra hole welded onto the pipe for afr/wideband gauge thats what i did
pazz1991
260
so , we have a pre and post sensor , why dont i just fit both back into place as it comes , wat do i do ??
Apr 15, 2009
2,189
Midlands
You do, fit both sensors in the same place as your old pipe
But as there is no longer a cat in place the second sensor will throw up fault codes and engine management light so you buy the spacer to space it further away from exhaust gas to stop this happening.
P1N3R
152
Preston, Lancs
Sam is bang on with the eBay one banging on the bulkhead. I bought one and it had to be taken off. I'll probably be geting it modified though to fit. It's not just the bulkhead I had issues with though - I also had issues with it hitting on the bottom of the car. A piece welding in to bring the whole thing down should sort it.
Chris
cupra-hodge
I've just put one of the decat pipes on from ebay, I can say that they are great quality but leave you with some issues. As mentioned a decat lambda extension will be required as my light came on after 10 miles of driving with the decat on..i've only just ordered it so i'll see what the outcome is.
However I have also got a EPC light on now and I have no idea what it is?
Can anyone suggest a fix or know what it is, sure it's been asked plenty on here. Thanks.
steveturbo
71
Just received my 3" eBay down pipe de-cat quality is top notch from what I can see and postage was stupidly quick let's hope it fits ok :)
casper20v
127
Am attempting to fit mine in 45 mins seen as garage free will let u all know how I get on
steveturbo
71
You going 3" all the way through? I have all the bits just need a good day to do make the system up.
