Drivers door handle loose
Mar 24, 2019
11
Hi all, wondering if someone could shed some light for me. My drivers door handle is currently loose. (inside handle) As of yet it is still working but would rather fix the issue now.
Is it likely to be the cable that needs replacing or the handle itself.
Also are they an easy fix.
Rhys
15
If its the same as my 06 fr there is like a spring loaded helper attached the the mech when the mechs fail people forget to put the springloaded bit on the handle happen on my passenger front door.
was kinda easy after working out how it all worked,
remove the fabric panel carful the clips are like wet paper wind the window down and your have full access to every real easy from there.
I unscrewed the assembly not the latch mech spring loaded the helper and put it back together. Need to remove the part next to the handle to.
I know it’s not a lot to go by but have a look see if you can figure out how it works when you take the fabric panel of
As i really suck at explaining things aha well good luck let me know how it goes!
Kenan
194
73
So if I get a replacement from someone breaking a car it's easy to change?
