elelctric Problem
adelelzomor
HI , I DID NOT CHECK THAT Points yet , but an Authorized Seat Services Center called me today , to follow up , they told me that this issue( Flickering Lights) is found in many other Seat Cars , so it does not belong to my car , it is some kind of some thing wrong , thay asked me to go for another free maintenace in a few days , untill then they will try to Solve this issue.
However, i will check the points for the battery volts , and get back to you once i go back as i am travelling for a few days.
regards
adelelzomor
hi , it seems that all Ibiza and Cordoba having the same Issue, as Nath Said.which is not Good from Seat.
adelelzomor
Hi ,puv .could you pls advise for my 2 threats above? Of silent indicators and ,85 hp or ,100 hp? Thank you
Pimped up vario
Cordy Cruizer
Nov 20, 2009
1,291
Belfast N Ireland
The threads must have been deleted. I didn't see anything about silent indiators, you'll have to explain a bit more. The horse power should be able to be obtained from the owners manual if you have it. If not give the seat dealership your chassis number and they'll be able to tell you straight away. I wouldn't know off the top of my head what the bhp figure is.
adelelzomor
Hi,for the horse power,i have the owner's manual but it is not clear.it is not important anyway.for silent indicators,they are working well as well as the hazards lights but with no sound .in their last day they were loud before going silent.thank you expert man
Pimped up vario
Cordy Cruizer
Nov 20, 2009
1,291
Belfast N Ireland
Mate I think I'm with you now. I'm old skool, I've never been in an 08 ibiza. In my car the indicators make there noise via a relay. I get the impression that yours makes an audible sound through a speaker or something. The indicators are working just not making a sound. According to haynes I'm a competant mechanic not quite a level 5 expert but cheers.:D
adelelzomor
well, i am not sure if it is a relay or speaker.
Seat Services Center told me that if i want to fix it , i have to change my dashboard !!!!
Also , is there any relathionship with my dimming lights issue ?
Pimped up vario
Cordy Cruizer
Nov 20, 2009
1,291
Belfast N Ireland
Do the indicators still flash? I wouldn't have though you need to change a whole dash to fix indicators. The issues could be connected. A poor earth in the system. Seat maybe isn't the best person to take it to in suuny Egypt. An autospark would probably be better. They should have the manual to cover your model and identify what part of the wiring may be giving you trouble.
adelelzomor
hi mate , yes i agree with you 100 %.
the indicators are working well and flashing as usual.
also the hazard lights is working well.the only issue is that they are silent.
what about AUTOSPARK ? Actually i do not know it .
Pimped up vario
Cordy Cruizer
Nov 20, 2009
1,291
Belfast N Ireland
An autospark is an electrician that deals specifically with car electronics and electrical systems. I'm sorry that I can't help on this issue as I haven't dealt with your type of electrical system and I haven't got the manual or electrical drawings either. My tick because a relay swithces on and off, if the relay doesn't tick over then the indicators don't flash so as I say yours is different and I haven't come across it yet. Sorry.
adelelzomor
Hi,an electcian workinv with skoda told me that my problem is my new bigger battery as the alternator regulator is not matching with that bigger battery,70 amp instead of 55 amp,so I need to change it back.
Any advise is much appreciated..
