EPC light staying on
pete309
The epc light comes on and stays on, it is not the brakes as the brake lights are coming on and off. I had some work on the clutch recently and it happened after that - does anyone know what it is? I mean, it is most likely clutch related, but what, exactly?
pete309
It comes on when I start the car and pressing the brake pedal doesn't change anything.
mty12345
4,114
680
bristol
EPC is the "electronic pedal control" and is related to the drive-by-wire throttle not the clutch. If they disconnected the throttle body during the clutch change then it probably needs reseting using Vagcom/VCDS. Either that or you have some sort of other fault with the throttle which should throw up a fault code when scanned with vagcom too.
