Faulty 007 DV??
LEON_FR
Rich Full Member
Jul 9, 2005
578
Stoke on Trent
The car is a juddering a bit not lots but you can sure feel it, specially in the lower gears.
Do you guys think there is something wrong with the Forge dv how could i tell for deffo???
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
take it off and push the piston up, stick ya finger over the end and when released see (a) does it pop back crisply with a click and (b) does it stay held up with ya finger on the end..
not known a dv cause judder tho.
easy to eliminate DV tho by checking it as described or swapping for your old OE one (assuming its not faulty)
PABLO ESCABAR
formally CUPRASMIFF
Jun 26, 2005
357
staffordshire
clean your throttle body out and this may help as they get very dirty on leons its a common fault.good look or pop along to the darlaston at 5 today and ill check if they need cleanin 4 you
ForgeMotorsport
This may help
We would normally inspect the valve every 12000 miles .
In order to determine if the valve requires a service I would recommend that you carry out the "leak back test" , in order to see if it is required.
1. Simply push/displace the bottom piston up to the top of the valve either using your finger, a pen or any suitable implement, whilst doing this cover the top small vacuum nipple with your index finger.
2. Leaving your finger covering the vac nipple, remove the pen, the piston may drop approx 5mm but should then stay in position by vacuum.
3. You should now see through the bottom port that the piston is held/drawn to the top of the valve .
4. Next, remove your finger from the vac nipple. The piston should return to its seat.
5. Repeat this test several times and if there is no gradual leak back all is satisfactory and the valve can be refitted to your vehicle.
6. If however the piston moves back down, whilst you have your finger covering the vacuum nipple, the valve requires servicing. If this is the case please contact us again and we will send you a service kit.
BHP Addict
Back in a SEAT!!
Jan 31, 2006
886
Birmingham
Sorry to hijack thread guys ..........
Forge, a quick question.
I have a 007P fitted (green spring) and from installation I had it running backwards (to test the noise) I have got bored of it now so have turned the valve to the correct position.
My yellow engine management light has now come on, I did an ECU reset and it went off for about 20 mins and came on again.What should I do???
Should I reverse it again???
BHP Addict
Back in a SEAT!!
Jan 31, 2006
886
Birmingham
ermm not really.
There isnt a drop in drive feel or performace really
It's baffelled me, it really has, and I'm worried about driving her too
honeyman
Pirates
Oct 20, 2004
614
Northampton
have a look and see what colour coolant sensor you have, the upgraded ones are green, for £20 it's worth a try. I take it you know where it sits, if not there's a pic on here somewhere. :)
