Fitting Aero Side Skirts
dannytremendous
51
16
Hi Everyone
I have just purchased and are on their way....... some Aero side skirts for my Leon SC.
They are factory painted so will just be a matter of fitting them.
Can anyone advise me on how this is done. I know they attach underneath and at the ends but what I want to know is.....
Can I use double sided tape where they attach to the car as I want to be able to remove them when I sell the car. So I don't want a permanent adhesive fix.
Any advice/ instructions will be greatly appreciated.
Danny
Reactions: donoli74
niallain
273
54
Cardiff
There is double sided tape already applied to the top of the skirts, but this is next to a channel to apply adhesive so it's more to complement and hold the skirt in place whilst the adhesive dries.
Only other advice I can provide is to have the front up on ramps and jack up the back to remove the rear wheel, made it a lot easier to fit mine.
donoli74
94
137
Hi Everyone
Danny
You have link where you purchased this skirts?
Verstuurd vanaf mijn Pixel 3 XL met Tapatalk
dannytremendous
51
16
Reactions: donoli74
dannytremendous
51
16
Did you use adhesive or just double sided tape?
I don’t have any ramps ☹️☹️☹️☹️ Is it going to be a nightmare lol
niallain
273
54
Cardiff
I used adhesive, the double sided tape already applied to the skirts seems to be strong enough, however I certainly wasn't going to test it alone.
Having the front up on ramps helped, however having the back jacked up and wheel off is part of the provided instructions.
dannytremendous
51
16
Ahh I may have a couple of axle stands so I’ll do it that way.
I don’t know what to do as I don’t want it permanent
SteveGSXR600K1
603
200
I would fit them with additional proper adhesive. When you come to selling the car, they can only complement the car and make it more desirable.
Reactions: Lmbarrett83
dannytremendous
51
16
I know what you’re saying. It was just in case I wanted to remove them.
I didn’t really want to do something permanent to my car as I am fitting them also, in case I make a mistake.
I have seen other members selling there skirts off there cars, so I wondered how they had done it.
k290b
116
88
I fitted mine with the clips that screw to the sill and tiger seal
The adhesive strip is just a weather seal and to hold the panel in place while the adhesive cures
I dare say without the adhesive they would be strong enough but I fitted mine permanently with the adhesive
k290b
116
88
I took the wheels off the front and back it made it much easier though you could just turn the steering I suppose
I have Audi jack pads under the car which made it easier as obviously you can’t use stands in the pinch welds when fitting these
dannytremendous
51
16
Thanks... it sounds like it’s going to be fun
I’m going to get some double sided good strength strips and see. I know they are also screwed at the end and underneath. I just worry I’ll lose one on the motorway but never lost a number plate with the sticky pads as long as clean the surface properly
k290b
116
88
It’s not a bad job to be honest
I reckon you could do without the glue to be honest they seemed pretty solid with just the adhesive strios
dannytremendous
51
16
Right if they fall off it’s on you
Cheers for the advice mate! I’m gonna put an extra strip on in case but I’ll see how solid! I trust your judgement
k290b
116
88
No worries. They defo wouldn’t fall off cos they’re well stuck in with the clips and screw-in the wheel wells but the worst that could happen would be there would be a gap at the top I think
dannytremendous
51
16
Brilliant. Well I will see and if a gap appears I’ll use adhesive. I’ll post updates when I’m done
