Forge 007 DV v Bailey DV
The Ross
I have the bailey DV on my 180 Cupra, Was recomended by John at Bedrock Vee Dubs in Motherwell that this would be the best for my car.
I see that a lot off people on here use the 007DV and was just wondering if this one was better that the bailey one as you do not see them mentioned as much.
Also got my car going in for a full service and getting my Cupra R front splitter put on so looking forward to my car having a new look.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
forge would get my vote as it can be easierly serviced. ive run bailey too and works well but i found mine sticking after a years use.
i now run the r1 valve which is diaphram based rather than piston, so should not stick or need servicing.
they are all good valves, forge is more popular but loads run baileys so it should be fine.
The Ross
If i am being honest, i wanted one for the noise and havent a clue what it is supposed to do.
Cupra's dont take well to blow off valves do they?
The Ross
i have a forge fitted but wanted to see how baileys would do on my car as been given one but been told not to fit it as it affects the fueling. is this true? thanks
Eh pass as i have never fitted a forge one before. But i never get past 290 miles on a full tank so i dont knoe if that helps.
Just by chance does the Forge make the same noise as the Bailey DV? is it louder or what?
warren_cox
Back from the dead
Can't see a DV which either holds on to boost pressure or doesn't can affect fuelling as such (unless the car holds on to so little boost you have no performance).
A DV is a DV. One may outlast the other, and an aftermarket one will enable a modified car to hold it's boost better than on OE DV, but other than that it's basically a glorified release switch. I've put a standard OE revision valve back on my car this month and the performance is as was with the Forge one as far as I can tell.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
If you get the spring tension wrong it won't boost as high.
I have never had an EM light with my GFB 50/50 got a turbosmart to try now, we shall see :)
Heat, nah I'm cool :D
he wasnt asking about 50/50s , i think the op was asking about proper blow offs;)
depresion
484
If you replace a recirc valve with an atmo one then you are letting out air that has allready been meatered and recorded by the ecu, so it's fueling for the aomunt of air it expects to be there, some of which isn't.
wilky87
154
Spot on there, with over fueling you tend to get a nice pop and bang :D
depresion
484
it wont damage te car or affect performance much will it, i have decat an like the popping an banging :)
You may have problems with unburnt hydrocarbons in the exhaust gas. Runing rich is less damadging to the internals than running lean, I wouldn't expect any long trem engine problems from it but your cat won't thank you (or wouldn't if you had one).
