The other day I attempted to fit my forge short shifter. However, I have two problems that are still unresolved:
1) I can't get the original shift off. The instructions say undo the 13mm nut and chock up the shift and tap on the top off the nut to undo the shift from the spline. I wish it was that easy!! Any ideas...?
2) When removing the cable circlip I dropped the circlip into the engine bay so now the connector is atached to the shift but not secured. Is this a problem? I guess I will have to order one from seat.
