Front wheel bearing replacement
mike_s14
105
staffs
Right have a increasing noise coming from the front end that I suspect is a wheel bearing problem
Can these be replaced and not a complete hub assembly for the 100 pd?
What sort of a job are they to do?
Skisbp
Looks like "(8) 6Q0407621AJ
wheel hub with bearing / F 6L-2-020 001>>*
72MM / AMF,BBZ,AZL AZQ,AUB,ASZ, ATD,BBY,ASY," is what you need & spares shows a 100euro value on the part alone...
mike_s14
105
staffs
right started the job today also decided to replace the broke wishbone bushes at the same time
anyhow didnt have a good start when I snapped the wishbone bolt :cry: so now got to remove the remains out of the aluminum housing
Is there a way of removing the hub without using the special tools or even better a guide to show how to?
mike_s14
105
staffs
took the whole wheel bearing and hub to be pressed out yesterday and they couldnt to it because of the shape of it they said
Is it a case of a big hammer to get the bearing and hub out of the housing?
ruidos99
i replace my bearings, but one of the disks scrashed , i am told its the spindle, where can i get one?
