That's how it works on the MK3 Leon and how I fitted my dash cam to that.Looking on YouTube it appears that I may be able to push two plug type things into the side and the glovebox should swing down!
Ill give this a go and let you know and if am lucky enough Ill get a picture of the fuse box for the group
Yes, thats exactly what I didVery handy thanks, presume you ran the cable up the door pillar and inside the trim along the top of the windscreen?
I had ran my blackvue on 4 cars using a powermagic box. Monitors the battery then cuts off before it gets too low.It was me that reported issues with my VZ2 while my dashcam was installed.
I have BlackVue Front and Rear Dashcams which have a parking mode setup which allows them to record if the car is impacted or movement is detected when the car is parked up for the night.
It has been noted that this parking mode is causing my Car Battery to run down to a level that causes errors to be reported with the car systems.
I am in the process of getting and installing a dedicated battery for the Dashcams which will be charged during normal use of the car and then used solely for powering the Dashcams for parking mode so as to save the car battery.
I note that you have connected via the Cigarette Lighter 20A fuse so you are not using parking mode as this does not hold power when the car is parked up.
It’s something to be wary of for anyone wanting to add Dashcams to their Formentor. Due to the technology in the car, there is a lot required from the battery. So if you are going to get Dashcams with parking mode setup, you will need a dedicated power source for the Dashcams when the car is parked up, otherwise you will get lots of car errors reported.
I wanted a 4k cam this time so went for a cheaper nextbase 622GW that wakes up and records if its parked
No issues so far
There is not much room behind the glovebox but there's loads behind the panel to the right of the steering wheelIve done some digging and the power medic pro wouldn’t cut the mark with the Formentor. As with my OBD powered supply they cut the engine off at 12V which still causes issues with the cars systems.
Ive gone for a BlackVue Power Magic Ultra Battery B-124X. Just need to figure out where to put it now.
Is there not a settings option to change the turn off voltage for these? I know that thinkware cameras do, so I would have thought the more expensive BlackVue would?
The power pack controls the voltage but even with that shutting the Dashcams down when it gets to 12v, there are still system errors coming up on the car.
It seems the Formentor has power hungry systems.
