• Hi Guest why not show off your SEAT! (now fixed)
    You can now share your favourite car photos in the new media gallery including embedding pictures from your Instagram account.
  • Hi Guest! New high quality keyrings are now available to pre-order: order yours now.
Gearbox oil change?
tuan21
My Cupra, my life style
Feb 24, 2011
328
Italy
Do you think I have to raplace the gearbox oil ???
Sometimes is difficult to pass from 2 to 3 gear and the gear is very hard. Car 43500 miles and I like very much trackdays (so consider the very hard use of my CupraR)
some days ago I passed from 2nd to 1st rather than 3rd And that's why 3rd really don't want to enter easily!!! :cry::cry: so much fear....
thanks guys
TimSawf
866
South Manchester
Can't seem to find any service interval for changing the oil on a manual gearbox on a Leon, only the DSG. Reading some articles, a lot of manufacturers claim it's no longer required due to modern oil, others say every 50k miles. The oil should be clean and cherry red in colour but very difficult to check on a manual without draining it. If it's going black or smells strongly, it should be changed.
Unless anyone else has better knowledge, I would check the level and top up if necessary. A full oil change should only be about 70-90 euros at a garage so not an expensive solution.
POPOV
Newbie
Jun 25, 2005
581
Sweden
I would say that your issues are not due to the oil. Sorry but i assume your gearbox itself is damaged.
I find the cupra R gearbox notchy getting into gears when cold (1st-2nd). My LCR has done 19k and is going in for a full service and stage 2+ upgrade on friday. THis includes a gearbox oil change to better gearbox oil. I was recommended stage 2 + changin your gear box oil every 10-15k
POPOV
Newbie
Jun 25, 2005
581
Sweden
Mine also feels notchy from first to second gear when cold outside. But i would assume that weather in Italy is not at the cold side this time of the year...
Changing the oil is worth a try
tuan21
Feb 24, 2011
328
Italy
Here 30+ degrees
note that:
-if I change gear at top rev 7000+ rpm 3rd not enter easy
-but if I change at 6000-6500 rpm have no problem..
-and this happen after clutch changing at33500 miles due to Revo map
Marshall
3,258
Bonnie Scotland
There used to be a few complaints about this when running the Sachs upgraded clutch kit.
If you went to change at redline it would not go into gear and this was reported as a clutch fault.
I've never had this issue so can't comment.
Sent from my iPhone
FSiLeonMike
Barmy Army Reservist (TA)
Apr 26, 2007
1,303
Bury St Edmunds/Stowmarket-ish
I am having trouble from 1st to 2nd, been told the VW gear oil is sometimes a bit ****, having a change doe, replacing it with some Millers
Also gonna see if they will check and reset linkage if needed
bisto48
84
Oxford
thanks guys
How about 4th to 3rd? That should be worse than 2nd to 3rd due to the synchroniser having to speed up the input shaft to match the ratio of 3rd gear.
bisto48
84
Oxford
Probably a linkage/cable problem rather than a gearbox problem then. Are the gear positions well placed still? Lots of sports shifts will stretch the cables
