Cupra R101 Full Member Aug 16, 2005 259 0 Eastbourne www.stevejayphotos.co.uk Aug 4, 2010 #81 Just gonna fit to the rear so guess 5mm either side ok To improve handling a bit and fill the arches more
Cupra R101 Full Member Aug 16, 2005 259 0 Eastbourne www.stevejayphotos.co.uk Aug 4, 2010 #82 Also would you recommend H&R over Forge as they also come with bolts
Damian @ DPM DPM Performance Forum Sponsor Mar 26, 2008 6,297 60 Newcastle/Durham www.dpmperformance.co.uk Aug 4, 2010 #83 Yeah you can go for the 5mm and yeah it is best to get the H&R's if you don't already have the extended bolts. Damian @ DPM Performance
Cupra R101 Full Member Aug 16, 2005 259 0 Eastbourne www.stevejayphotos.co.uk Aug 4, 2010 #84 Cheers for your help Damian Would 8mm either side be too much if just doing the rear?? Am lookin at 67 plus postage for 8mm either side??
Damian @ DPM DPM Performance Forum Sponsor Mar 26, 2008 6,297 60 Newcastle/Durham www.dpmperformance.co.uk Aug 5, 2010 #85 No 8mm would be fine, most people tend to go for at least 10mm normally. Damian @ DPM Performance
Cupra R101 Full Member Aug 16, 2005 259 0 Eastbourne www.stevejayphotos.co.uk Aug 5, 2010 #86 Hi Damian so do a lot of people put 15mm on the back either side?? Seems to be what some do on here
Damian @ DPM DPM Performance Forum Sponsor Mar 26, 2008 6,297 60 Newcastle/Durham www.dpmperformance.co.uk Aug 5, 2010 #87 Yeah usually between 10 and 15mm. Damian @ DPM Performance
Cupra R101 Full Member Aug 16, 2005 259 0 Eastbourne www.stevejayphotos.co.uk Aug 5, 2010 #88 Ok thanks Is it right that as standard the front of the car is slightly wider stance than rear? Someone on here said that to promote understeer
Damian @ DPM DPM Performance Forum Sponsor Mar 26, 2008 6,297 60 Newcastle/Durham www.dpmperformance.co.uk Aug 5, 2010 #89 Yes that's right. Damian @ DPM Performance
Cupra R101 Full Member Aug 16, 2005 259 0 Eastbourne www.stevejayphotos.co.uk Aug 6, 2010 #90 One last thing so if I went for 15mm on the rear What would you recommend on front 5 or 8mm
Damian @ DPM DPM Performance Forum Sponsor Mar 26, 2008 6,297 60 Newcastle/Durham www.dpmperformance.co.uk Aug 6, 2010 #91 8mm-10mm on the front and if going for the 8mm stick to the ones with the collar. http://www.dpmperformance.co.uk/hr-...centre-bore-571-bolt-thread-14x15-p-4790.html Damian @ DPM Performance
Cupra R101 Full Member Aug 16, 2005 259 0 Eastbourne www.stevejayphotos.co.uk Aug 6, 2010 #92 Another Quick Q why do I need the 8mm with the collar??
Damian @ DPM DPM Performance Forum Sponsor Mar 26, 2008 6,297 60 Newcastle/Durham www.dpmperformance.co.uk Aug 6, 2010 #93 It's better for locating the wheel and eliminates any chance of wheel wobble. Damian @ DPM Performance
Cupra R101 Full Member Aug 16, 2005 259 0 Eastbourne www.stevejayphotos.co.uk Aug 6, 2010 #94 I am guessing the 10 and 15 being thicker are ok Hope to order some 8s off you soon
Damian @ DPM DPM Performance Forum Sponsor Mar 26, 2008 6,297 60 Newcastle/Durham www.dpmperformance.co.uk Aug 6, 2010 #95 That's right, they come with the collars. Damian @ DPM Performance
