Help needed with Angel Eyes
snakebite15
Graham from Cornwall
Jan 1, 2006
172
Cornwall
Ok cool, so what just take the plug off and wire them in? well as iv just gone through the trouble of getting pics i'l show you what i ment -
standard lights (wheres the plug?)
angel eyes - plugs
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
J@mes said:
yes! :(
hence why i REALLY think they were not worth having UNLESS u HID them!
Well i uprated the standard bulbs and am so sick of the passenger side sidelight bulb blowing every month (the nightmare side to replace) that im getting tired of them and fancied a change
taken it into consideration though james, thanks for the information!
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
angel eyes - plugs
its right there!!!!
follow the wires goin into the back of the headlamp and it goes to a plug! :yes:
and unplug the plug to the indictor aswell for the indicator plug on ur angel eyes!
easy peasy! :dance:
snakebite15
Jan 1, 2006
172
Cornwall
what......follow the wires goin into the back of the headlamp and it goes to a plug....yes, but think about it....oh it dont make sence to me but it does in a way im crap at these sort of things, i'l just look tomorro and prob find out your right but if your not i'll re-post ok cheers. Does it just mean that those standard wires are kept, and that plug just plugs into these new ones? its probally confusing me because the plug is on wires and not built in or some **** like that. excuse the french sorry
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
those wires go to a plug which plugs into the back of the headlamps.
u unplug it and remove the head lamp, fit ur new lights and plug them in!
it really is easy m8!
just have a good look at it! :yes:
daboy3000
No Longer a Seat owner
Jul 2, 2008
710
Oxted
Just had my angel eyes delivered and on the bottom of them are more wires coming out, all black and red so i guessing power but what are they for? It has the normal plugs on the the main loom coming out of them but these other ones are bare at the end. Do I need to wire the actual "angels eyes" up seperately?
daboy3000
Jul 2, 2008
710
Oxted
How do i wire them in? and do they need to be connected to a switch?
Can provide pics if it helps
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Wire the red to live and black to earth of the side light bulb circuit.
You'll find you have the rings and another strip lit up possibly, if you don't want the strip lit up, just disconnect them :)
daboy3000
Jul 2, 2008
710
Oxted
Ok, following so far, i think there are some leds which i probably won't connect. How do i know which wires the side light circuit is and do i need something to connect them?
Sorry for all the questions but i thought they would be plug and play and i'm getting worried i won't be able to do it.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
The sidelight wire will need fixing to the red and black wires somehow.
If you have a meter, or can follow them by eye, that is better than guess work.
You need to find how they enter the standard unit, never had to do them on a Leon.
If it was total plug and play the sidelights would b connected up already ;)
Just a bit of wiring is needed.
daboy3000
Jul 2, 2008
710
Oxted
Is there a good way of testing what set of wire does what before i spend ages wiring them in only to find that i don't need some of them, eg. could i use say a 9v battery just to see what light up!
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
You are only not going to wire in the extra leds, a 9v battery might be enough to show you which wire you wont be connecting, failing that easy to remove the cars battery cover.
daboy3000
Jul 2, 2008
710
Oxted
Is it safe to connect them directly to the car battery, wasn't sure and didn't want to blow it up.
Thanks for all your help and quick responses Lee, i promise i'll only ask another 50-60 questions!:doh:
