Help with Subframe Bolts PLZ
azbaz125
Hey im getting a knocking noise sounds alot like the subframe knock some people are getting at what Torque should tighten the bolts to in NM Thankyou.
AlecEiffel
45
May have a similar issue......
Only symptom is when I reverse after driving or being parked, when I touch the brakes I get a very slight thud/click sound, just once, and feel a bump through the brake pedal.
I've read in various places that it could be anything from a ridge on a pad, a loose caliper, and loose pad, or loose subframe bolts.
Anything like that familiar in this context??
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
what you are describing is totally normal.
its the brake pad resitting itself , mine does it all the time.
they are also a bugger for sticking a little if you wash your car then leave it overnight then pull away in the morning you get a slight thud as well as the pad frees it self up.
TimSawf
864
South Manchester
One way I've found to avoid this is to, while parked, leave the handbrake off after washing it until it's been driven for 4 or 5 miles.
