Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
My car (Cupra 280) made the following as a stock car.
302bhp at the flywheel on REVO's hub dyno, 308bhp at the flywheel on a Maha rolling road.
it also made 312bhp at the flywheel in "stock mode" which was a setting on the REVO ecu that was also running an intake as well though.
Several others have all made 300ish standard.
The reason for this, when I did the REVO development back in 2014, when they took the OEM file off the car and opened it in and editor and compared it to a Golf R file it was actually the same file.
Should that not say 'Estimated 308bhp at the flywheel', given they are using an algorithm to try and guesstimate the transmission losses?
My Cupra 290 DSG when I put the power down on the front wheels hops ayway, so why do you need more power, you can only do a legal 70mph on the motorway!
When I first got my 265 I had the same issue. It took me a couple of weeks (I don't do many miles) to get used to it and i haven't had wheel hop since. It's how you put the power down that makes a difference. I'll need new front tires soon so going to get something different to the conti sport contacts 5's and maybe an uprated engine mount so I can get on the power a little harder earlier when I want to.My Cupra 290 DSG when I put the power down on the front wheels hops ayway, so why do you need more power, you can only do a legal 70mph on the motorway!
