for a long time now (in fact i cant remember a time when it didn't do it) i get a clunking when accelerating in lower gears. it doesn't happen so much when travelling at speed, but pulling out of junctions or changing from 1st to 2nd or 2nd to 3rd it does. (or perhaps its not as noticeable)
for instance say i pull away in 1st up to 20mph then let off the throttle it will clunk when i first pulled off and again when i let off. There are also strange noises that i cant really describe. Also there feels like a vibration not only through the pedal but under the floor in the foot well too.
also it doesn't happen every time, perhaps if I'm careful and smooth on the throttle and the clutch it won't make a sound at all.
there was a time when i thought it was the EDL functioning, then thought maybe it was the DP knocking on something. then i went to engine mounts, but i can find no play at all.
i had my passenger side outer cv replaced after it snapped a few months after i purchased the car. i'm wondering now what if its the inner cv causing the clunking sounds. only problem is how to diagnose this.
any comments, experience or advice on this? this really is the only annoying thing with my car, however it does drive fine, infact its never been better.
cheers
cheers
