intercoolers apart from forge ?
Jan 31, 2012
703
Sheffield
Very interesting. Any fitment issues.
Had to trim a little bit of plastic here and there but nothing major pal flesher purchased the radiator off me as I didn't want to fit it
But really made a difference mid range water meth next you going to gti festival
Jan 31, 2012
703
Sheffield
my intercooler.do you think i should cut these front plastics?
Cut the plastic away pal better air flow
yannterzi
Lookin good for this price!
Any problems to fit this on a 1.4tsi ? like fixation or hoses ?
cloudfr
i will take some and upload them asap
thank you very much, so I do not speak Spanish very well English. my car is a 2.0 TDI CR and Bocanegra has left me the opportunity to mount an intercooler like this. I wanted to see how it looks with the bumper because it seems that is very nice.
cloudfr
very handsome. see the difference? is a polo / fabia that ENGINES? and if not too much trouble, could you tell me the approximate price? thank you very much and sorry for the inconvenience
Mar 13, 2010
822
Its a shame there is no universal ones in the uk, as there are loads of cheaper companies than the likes of forge, id get one if they wer cheaper.
cloudfr
How about temperatures? Have done with the intercooler mounted logs before and after?
Cells in the intercooler are good? ic appears the same as that of the mark wiltec
Thank you.
andrewfx1
51
Thank you.
there was a huge difference.....before with 30 C outside after full throttle for a little time it reached almost 70+ degrees.....after i fitted the intercooler with the same outside temp it didn't get over 45 C degrees and after leaving the pedal the temp fell rapidly to almost 33-34 in contrast with before that needed many minutes to drop down....
cloudfr
It's a big drop in temperature! Have you noticed some turbo lag?
Thank you!
cloudfr
no i haven't noticed any turbo lag...i feel the car just the way it was before....maybe the compressor eliminates the turbo lag....
For perfect, you convinced me to get one at all. See if I order and prepared to mount. Although I have to remove the DPF.
Thank you!
