Interior trim
SwissCupra
81
44
Switzerland
What do you guys use to clean your interior trims with? Specifically the lower door trims, I tend to scuff mine with my feet getting in and out as the parking spaces aren't huge in our parking garage.
Did try searching, but other than an Autoglym product I didn't see anything else.
Ta.
Reactions: Oliver Pawley
Jimbobcook
6,149
2,531
For me if it's black plastic I use meguiars ultimate black... If its metal then probably autoglym metal polish...
Reactions: SwissCupra
ChrisM75
423
182
CarPro PERL. Its awesome stuff. Can be used on plastic, engine, rubber and leather (hence the name). Its a water based ceramic dressing, and it does give good protection to any plastic. I use it on tyres as well for a natural sheen. It can be diluted so that if you don't want a gloss it wont leave your dash too reflective.
Reactions: bruceR
gurpz94
167
72
I used to use Aerospace 303 cleaner but any diluted APC works perfectly fine at around 1:8 - 1:10. If the muck is really stuck on the 1:5 would be better.
bruceR
2,538
616
Monifieth, Dundee
+1 for CarPro PERL, so many applications and it can be diluted which makes it even more economical.
ChrisM75
423
182
Indeed. 1 Litre pretty much makes 5 for most applications. Ive been over the entire interior of my Cupra, the plastic is a little flat on these cars, quite dull, the PERL gives it a darker sheen without leaving it shiny or sticky.
