intermitant misfire
scottambrose
when my 150hp v5 is cold it sometimes misfires under load ie 10mph in second and accelerate. its like this for say 5 to 10 minutes then its ok. its had new plugs and leads about 2 months ago and this faults only occured in the last week.
Dox1966
243
After quality plugs and leads the usual suspects are coil pack (cracks on the back) ignition amp and (wild card) crank sensor
You could refit the original leads to check the new leads are OK?
Don't pull on the wires themselves, this breaks them internally leading to misfire
scottambrose
okey thanks. someone else suggested a maf sensor. so will try all of those thanks
RoddersV5
87
Reading, Berkshire
Have you tried resetting the ecu since the new plugs / leads etc.? Mine was a tad lumpy from cold after a service in the summer, reset the ecu and all sorted itself after that.. Cheap easy fix, if it is that..
