Key programming. Only one key
Oct 22, 2019
Hi,
If I'll do key program will it start the veichle or just unlock the car remotely?
Is it possible to get a new key and program it if I have only one key?
Thank you very much.
at0ny
155
32
Holland
Only lock and unlock. For immo you need keycode or code it with odis.
Verstuurd vanaf mijn SM-G965F met Tapatalk
Oct 22, 2019
Do you mean immobilizer?
Can you explain a bit on that keycode and odis?
I see that I can obtain my car's keycode from the dealer. I will try it.
Thank you
at0ny
155
32
Holland
Thank you
Yes immo= imobilizor keycode is the 7 pincode from dealer somethimes in papers of the car. Then you can code it with vcds etc.
Odis used online cpn connection with dealer portal. Its special function and needs geko acces. Then you can code keys for immo. Dealer wil use odis.
